I have a problem with my start
I have a problem with my starter. I turned the key and heard a click sounded like the solenoid was engaging but not turning. Both batteries are fully changed. I moved the fly wheel and banged on the starter and tried again and it turned over. I waited a few minutes and tried again and I heard the starter turn but not the engine. I went and purchased a new starter. I installed it and now I can get the engine to turn over but sometimes it won't and just get a loud click like the gear is going out but not turning. Which is one of the problems the old starter had. If I keep turning the key multiple times eventually it will turn over. It is random but happens a lot. It seems that once it starts to turn over it will continue to. I checked all the connections and cleaned and replaced any dirty contacts both on the starter and the key switch. One more thing I saw what looked like an arc from the starter to the transmission housing I think. Do I have a bad ground? I cleaned the ground from the battery to the block. Do I have to clean the bell housing where the starter bolts to? HELP!! I want to go in the water this weekend.
