Crusader Damper Assy
mac9427
I have a 1987 Sea Ray with 454's and 10-18-04 velvet drives. I need to replace the damper assy P/N cru97334. I have bought two from seperate crusader suppliers and neither one looks like the original one that I removed. Does anyone know if the old stock is still available or has it been superseded. I really want to use the old style, it seems much more robust. thanks MAC
I had to change mine last July and it was CRU97334 as you have listed. It was round and looked like the old one in that it was a little less in diameter than the flywheel, had the springs in the center and the splined center core. What specific differences are you seeing and do the new ones look like each other if not like the old one? My engines are 1992 and call for the same part #
The old style has six heavy springs captured by the hub and there is one mounting hole for each screw on the fly wheel. The new one i just bought has eight purple springs (not as beefy) with a cable looped through them and has 7 mounting holes for each hole on the flywheel (use for use other size flywheels). The actual plate that bolts to the fly wheel is approx .05 thinner then the old style as well.
Gee Mac,
I know mine had purple springs also but it was late July and I just can't recall any other specifics. I doubt I could feel the difference between thicknesses, especially .05 and never thought to check. This was the part number, so... I put it in. As for those mounting holes, I do remember several. Used red Loc-tite though.
Thanks for the input, I am going to use one of the ones I just bought. There doesn't seem to be any old stock around for this items (oh well)
Mac,
I found a closeup picture of my old damper.. It has 8 springs and a steel wire insert. A bunch of holes in a triangular pattern on the outer radius. I tried to post a picture but...I just can't figure out how
Yes sir, that is the configuration of the new one that I have purchased. They might have discontinued the older version before 1992. Is your engine a 454, 350 hp?
Yes...they are 1992 454...350HP By the way: Here is an attached picture of the old one....a bolt let loose and the centrifigal force caused it to fan out and jam against the bellhousing...SLICING the insides like a soft tomato while accelerating from 1000 to about 3000. Felt like I hit an underground telephone pole
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
105015-5860
105015-5860
105015-5940
0 433 171 134
0 433 171 137
0 433 171 146
5611065 H60S30A538
5611650 BDL110S6133
5611735 BDL110S6267
6801082 6801082
6801087 6801087
6801088 6801088
DN10PDN130
DN0PDN121
HL176S27D525P2
2418455518 2455-518
2418455714 2455-714
9401087506 9087-506
134151-4120 P121
134151-4920 P129
134151-6420 P143
NOZZLE DENSO 093400-7690 DN10PDN129
NOZZLE DENSO 093400-7700 DN10PDN130
NOZZLE DENSO 093400-8220 DN0PDN121
131110-9320 131110-9420 131160-0320
Mac did u take tranny out while in water or the boat was on the hard?? Also was the removal very dificult or not? I have to remove my tranny for repairs this week and iam in the water and wonder if it can be done? Same engines and tranny as urs just different boat
Hi, The boat is out of the water. I dont think you should have a problem in the water. See the attached picture. I used 2 saw horses, one to hold up the engine and one to remove the trans. It weighs about 125lbs. You will have to align it when it is re-installed. I'm waiting to final align mine after it is in the water a few days. Should be fun!!! MAC
