1973 Browning Marine
Hey Dennis, I saw your posts on breezeworks a ways back. If it wasn't for that site I would never have been able to rebuild my engine. stractor is the man on there! He helped me tremendously. I was pretty much in your shoes about a year ago and did everything you are asking about. You will be glad you did what you are doing now. I also run NGK plugs and have had absolutely great results. I was wondering if you went with the flamethrower 40,000 volt coil? That is what I bought and it works great. I have a four barrel carb. on mine and the motor seems to run great set around 5-6 btdc. with the pertronix setup. My engine won't idle as well at 4 btdc. Oh yeah, being that the engine has a short advance curve, guys on breezeworks mentioned that you should try and get idle down to around 600-650 or as low as possible before going ahead with the timing light. You will like the pertronix if you take your time to set everything up right. talk to you later, Tom
