How is it that you know the OP is doing this test themself?A healthy 1995 Mercruiser 5.7 VORTEC should give you a cylinder pressure reading of approx 140 to 160 psi per cylinder, and with no more than a 10% differential between the lowest and highest reading.
If using this style cylinder pressure gauge, the pressure will be accumulative.
This means that you will want to cycle each cylinder through at lest 3 compression strokes per reading.
Healthy battery, good starter motor, all spark plugs removed, and with the throttle plates just partially open.
Be sure to disconnect the power to the ignition system. In other words, do not just simply remove the high tension lead from the distributor cap or ignition coil.
Actually if the question was read right, I posted What the compression SHOULD be? I took the test and all cylinders came in good. But how far from knowing what the compression Should be. No manual I have states VORTEX in the specs.
