Long story short I was replacing spark plugs and found coolant in cylinder #1 from when I winterized it. Mercruiser 454 (L621109) raw water cooled. Compression in that cylinder after cleaning it out is excessive I believe. Between 200 and 225psi. The next cylinder #3 is only Between 50 and 75psi. Very low. All the others are ok I believe, they are in the 120-160 range. I'm thinking a new head and all gaskets but I'm just wondering if I'm missing anything. Used in salt water if that matters and roughly 1'000 hours on the motor. Any help would be greatly appreciated.
