Mustang67ford
I have an 1987 classic 50. Its been in my garage over winter. Just ran it with muffs about a month ago after changing the water pump. Last week, I noticed a thicker black oil on my floor under the motor. I determined it is comming out from the lip the prop recesses back into. It definitelly is not the gear oil lube I put in fresh when I changed it this winter. It lo ok ks like a very thick motor oil, almost like a thinned out grease. I wipe it up and then a few days later a couple drops are back. Only work I did to the motor was changing the water pump. Any ideas on what it is?
