dimitrimfogal
this engine in a 68 sea ray w electric shift. '78 305 chevy 2 bbl. sarted this for the first time today . i ran a clear temporary gas line from fuel pump to gas can. i poured a little gas in the carb and she fired right up. it idled for a couple minutes then died. i sprayed in some carb cleaner and fired up again.. ran for a minute and then died. i repeated this several times and cant tell if the fuel pump is weak or carb is clogged up. in the last couple of month ive read many threads so i did check for a couple thing as follows...1 pulled filter off of carb and surprised it had not been removed by previous owner. 2 viewed the temporary fuel hose that i attatched (clear) and did notice that it did not keep a continuous stream . it was not full seemed to have a fair amount of air in it. not sure if my connection was sucking in air or the fuel pump is sucking in air.either way i thought id post my results and see what you guys would have to say. also i had my seloc manual out there with me and discovered that my rochester carb was not in the book so i got the p n off it and gonna search and find what it is exactly. basically i could get her to run for a couple minutes and rev it up a little and it would sound / run awesome then the carb would sound like it was sucking air and quickly die. whattya think? thanks in advance...dimitri
