I own a 2004 J90PLSRR and have been having a devil of a time locating an electrical problem. Started out by losing rpms and slowly stalling, then progressed to suddenly dying and wouldn't restart for awhile. Started with the obvious stuff; fuel, fuel filters, fuel line, found a bad gasket at the vapor separator and replaced...still acting up. Checked spark with an inline spark tester...fine when running but nothing when it won't fire up. I replaced the coils, no luck; put in a new power pack, the same result. Now I'm at the rectifier/regulator; checked the resistance on the yellow and yellow with trace to ground, reversed polarity and got the same readings ~87 kOhms on yellow and 29 kOhms on yellow with trace. Shouldn't one polarity be zero/infinity? My limited experience with older smaller outboards tells me the diode(s) are bad.
My Seloc Manual doesn't give me any expected ranges for my 90, neither does it clearly explain what me charging coil voltage output should be.
Anyone have any experience with this issue or happen to have the magic numbers I'm missing?
Thanks in advance
Thanks in advance
