Hi, Please bear with me as I try to give as much info as I can,,,,I have an 18 ft 88 bayliner with an Omc 3.0 engine and outdrive. It runs fine, shifts fine and has no problems, but as you know, it lacks power. It was ok when the kids liked to be pulled around in tubes, but now that they want to ski, and it needs more power. Selling and buying a more powerful boat is hopefully a last resort as I really like this bayliner, and it is now in good shape. Two years ago (with much help and advice of this forum), I replaced the entire floor and stringers, and fixed or replaced almost everything that it needed and now everything works well. Now I need your help again. I have obtained 18' sunbird with a good running omc 4.3 (2 bbl carb) and with a good 4.3 lower unit that was practically given to me. The 4.3 boat runs fine, but the floors, stringers and upholstry are shot, so I don't think it's worth the money to fix and sell. (plus my wife doesn't want any more boats. So I thought I would try to put that combo in the bayliner. Pulling my 3.0 is easy, as well as removing the outdrive and changing the lower unit over, I understand I have to swap everything over and can handle the electrical, gas lines, etc but I have some questions I have not heard anyone talk about before. Does the gimball assembly need to be changed? they look the same but I am not sure about the inner plate that attaches the rear of the motor mounts because I don't have the boats side by side yet, Also, how do you align the engine with the side mounts on the stringers instead of the front mount as in the 3.0. The 4.3 has power steering, do I have to use that? or can I just keep it simple and manual how it is? Any advice will be greatly appreciated. I read this forum daily and think it's advise is worth its weight in gold.... I am planning to do this over the winter when I have lots of time,,,,,
thank you again for your advice...
