Hello all, first time posting here and I'm hoping to get some help from all the intelligent folks here. So first off, I have a Johnson 150 fast strike. The SN sticker unfortunately is melted and dirty and I cannot seem to read the numbers for the model number, but I can tell you that it is a 2000 Model. Now the issue I have is that in the tilt position, the carburetors leak, significantly. I know a little leakage is normal but I'm dumping about a cup when the motor is trimmed up to about 30-45 degrees. But I'm researching parts on what I believe is the model, and from what I have gathered, the carb. body has p/n 436798 which I think was replaced with 436850 and later 439756, however, down that rabbit trail, I cannot find what replaced 439756 as this info is unavailable and without the proper model number, I cannot search on BRP's website. Any help would be great, also if there is a metal replacement, I'd prefer to go with that as the plastic one has warped on the body and the bowl. Thank you in advance.
