With engine idling I pulled off one spark plug wire at a time and the lower starboard cylinder was the only one that didn't show a difference.
Swapped the plugs and wires and had the same results.
Swapped the lower carburetor assembly with the upper. The problem moved to the upper, followed to carb. Completely rebuilt all 4 carbs (new floats, needle valves, gaskets, etc...).
Sill have the same problem......Any ideas????
Also seem to have a fuel flow problem, separate issue ??
Out on the water under a load the engine bogs down. When I squeeze the bulb multiple times the engine takes off. I replaced all the gaskets on the fuel pump, made no difference. No sign of gas leaks when priming bulb.... Any ideas????
Thank you in advance.
Vin
Vin
