The main bolts are usually at the bottom.2. Remove then then loosen the engine mountings to the transom to make wider by about 1 inch and the unit should come free.
I just saw your question about drilling out the release. I have been told it can be done, but if you slip, your tilt/trim assembly is trashed, and you can't remove it without the engine fully tilted.Try draining that oil first.
