Hi,
I have a strange problem with my BF15. I can start the engine manually, but the starter doesn't run when the start button is activated.
I found out that their is no current on the wire from the EDU. If is bypass the EDU and connect 12v to the wire comming out of the EDU then all work as it should and the engine start when the start button is activated.(off course only when the gear is in neutral).
Do anyone have a suggest to why there is no "juice" in the white-black wire from the EDU and how to fix it?
