1984 Evinrude E30ECRR (30 hp)
Ser: F036841
I had to remove the starter to pull/clean the carb, and when I reinstalled the starter, I over-tightened one of the nuts on the starter bracket and snapped the mounting stud. I got the OEM part from a local shop, and after doing a lousy job drilling out the old stud, chose to make the repair using original JB Weld 2-part resin epoxy, setting the stud in the resin because this mounting sits under the flywheel and is very hard to reach/drill. The repair seemed to work fine, but the last time I took the boat out, it failed; the JB Weld cracked, but the surround metal is fine. I recently watched a Project Farm YT video (link below), and noticed one major thing I did wrong, which was to not drill out the hole to a larger, consistent size to give the JB Weld more surface area. I am thinking of trying this repair again, correcting my drilling error and using the winning product from the video, JB Weld Epoxy Putty: https://www.amazon.com/gp/product/B...&linkId=78ff060242475aeb03bf1612660f08db&th=1
NOTE: The mounting is part of a plate that's on the front (boat side) of the engine that holds the carb (intake manifold?). I think it's aluminum. Any tips/products y'all might suggest to give me a better shot at success are appreciated. It's been a great little pontoon motor, and I hate to think that I kilt it.
Many thanks, PW
Ser: F036841
Many thanks, PW
