SpeeedRacer62
Greetings, I have two Bravo 3's that were both leaking at the seal between the inner and outer shafts. Plus the corrosion was so bad on both bearing carriers I decided to have my trusted local shop replace these 4 items since I do not have the proper tools. After they assembled both lower units they found that both had quite a bit of side to side play (not end play, not back lash). If you have the unit mounted in a holder and grab the outer prop shaft and move it up and down, there is slack, maybe .035-.050
They're not sure if its the tapered bearings on the front and/or rear gears or something else. It has new bearing carriers so its not that. We dug thru the #28 Service manual and couldn't find an actual value for this type of play, but both mechanics there felt it was excessive.
Has anyone dealt with this type of play? I'd appreciate feedback from those that have seen this and might have a solution. These are 2004 lower cases and the serial numbers of the drives are OL470455 and 56.
