jasondainter
Hi Folks.
I have a Johnson 55HP from 1980 (engine model 55EL80C).
I was reassembling the cover assembly (where the shift rod goes through) and retightening all the bolts. In the manual it states 7/16 bolts need 38 to 40 Nm of pressure. So I started tightening to 38, and SNAP, bolt snapped off (so annoying!).
So I figured, well I must have been doing the right pressure, I mean the manual says so, so I tried again on another bolt, SNAP. same thing. 2 bolts down.
So then started looking up the replacement bolt I need, which in the parts manual says its part 307151.
After googling on ebay I find that this is what that bolt is supposed to look like, seems similar in length but the bolt head is chunkier and there is an additional tighetning washer on there as seen below:
However the bolts I took of (which I managed to snap 2 of) looked like this below. Similar but thy seem to me to have a less thick bolt head, and they miss that tightening washer part also...
So this leads me to believe that possible the bolts I have in my casing might not be original and the previous owner may have replaced them? Could anyone in the know confirm that might be the case? It would perhaps explain why they snapped at the right Nm pressure also.
So i'll have to order 2 more 307151 parts, however I'm confused about one thing. Unless I'm mistaken (which could certainly be the case) It would seem to me that this bolt is supposed to effectively act as a seal between the top of the bolt head and the cover assembly housing. But would the type of bolts seen in the first photo (307151) not create a small gap where those tightening washers go? Im worried if so that water could get into the gearcase as from what I can see theres nothing to stop water getting in other than that bolt being tightened against the casing.
Am I missing something?
