With the cap off, you manually open the points and get a spark from the coil wire? Leave the cap off and turn the motor over w/ the starter and see if you get the same spark. Observe the points in action, with the lead from the coil to a good ground (set a spark plug in the wire end and lay it on the block and see if it sparks to ground). Also connect the dwell meter. Hint: the smaller the point gap, the higher the dwell. Longer time points are closed, the more time the coil has to "charge up". If points are opened too far, then the coil won't have long enough to charge, giving a very short dwell angle. Don't remember the settings as it has been a Looooong time since I messed with points.
If the same spark is present, put cap / rotor back on and do it again. If no spark from plug wires, then bad cap or bad rotor or bad wires. Seen many rotor that shorted out to the middle, into the steel distributor shaft underneath.
Let us know the results.
Pops
PS: Riccardo's troubleshooting techniques are top notch, as he really knows what he is talking about. Follow his suggestions and you are working in the right direction.
Pops
