Pat Miller
Hi, I have 9.9 that we bought used I think it's a 2001 or 2002. So here is the facts. Last year the engine ran great. We pull the fuel line and run it dry after flushing fresh water through it ( used in saltwater on a sailboat). This year we tried to use it and found it sputters when put in gear. It seems ok in gear at idle but not when you throttle up.
With the engine not in gear we seem to run smooth but it does not rev up as high as I remember. It almost seems like the engine has a rev limiter on it.
We have replaced the gas, added sea foam, replaced the fuel filter, replaced the fuel pump, removed the carb ( it looked very clean inside) and did a dock side inspection blowing air though the passages. I removed the jets and they were clear. It really seems like a fuel problem, but starting to doubt it.
The engine starts up usually with just one pull and seems smooth at idle.
Any ideas? Anything electric or spark related? Does this engine have some form of timing advancement as the revs increase? Suggestions?
Thanks for any help
Thanks for any help
