Hi
so i took my boat out today, for a test run.
Everything seemed fine then notices a milkshake brewing in the engine cover (leaking out)
Switched off immediately, took her home on the sneaker motor
When i get home i see the pee hole pipe popped off and seemingly flooded the casing, which i can only assume caused water ingress into the oil tubes at the top of the set mount.
Ive heard of this happening before.
I forgot to zip tie the pipe so when it popped off it flooded the engine cover and of course the sump.
Ive drained and removed the oil filter, and ran about 5L of oil through the system,
Next procedure for me will be to flush with a new filter and oil, drain and put new filter and oil in.
Is my logic flawed with how the water got into the sump,? Motor started ran and no beeps etc.
is there anything i can do in this instance? I checked the plugs were dry and there was not oil/water ingress into the combustion chambers
thanks again for the advice:
