I bought this engine used and have gone through a number of issues, it's a later DK4 engine that was originally NMEA compatible and was converted to older electronics (DK0 or DK2) I have gone though the entire parts list and replaced all the non-compatible parts that were left behind (O2 and oil pressure sensor) but everything else is the same, including all 3 temp sensors, also I purchased a complete spare DK0 motor which I'll be parting out once I figure out what I'm keeping for spares, and I confirmed the sensors and the rest of the parts are all the same
So that's the back story, the issue I can't resolve is described below, also it's on a 20' pontoon
When I got the engine it had a number of running issues and while chasing those I pulled and cleaned crusty temp sensors in the head and block thinking that inaccurate temp reading might affect the mixture (lean between 2,000-3,000 rpm) but after cleaning the sensors I started getting an overheat alarm at WOT (5,800) I assume before I cleaned the sensors they were insulated enough with crust and did not reach the 75ºC and now that they are reading more accurately they set off alarm and limp mode after couple minutes at WOT. I can run ALL DAY at 5,500 and they stay in the low 70º range (monitoring on the data stream using Heal-Tech)
*Tested all 3 temp sensors with multimeter and on also data stream, everything checks out, using Honda shop manual for reference for Ohms and temps
*Both thermostats and covers are new, covers were warped and leaking
**I was told the original harness and ECU were damaged by seawater from what looks like the block thermostat leaking RIGHT ON THE ECU connector, so whoever replaced all the electronics didn't bother looking for a water leak!!** |
*T-stats replaced as a precaution, both installed correctly 50º and 60º according to manual, but it didn't change anything, still overheating
*Strong water flow from every place I could test
*Did a trashcan with vinegar bath and it didn't change anything, nothing washed out either
*Removed RR to take a look and the manifold, inside doesn't look crusty, anodes are almost new, I might remove the manifold cover but I don't see a point.
*AT SOME POINT CYLINDER HEAD WAS REMOVED
I'm at the crossroads:
*Do I try another vinegar bath and hope for the best (it was a pain, whole neighborhood smelled like vinegar for days)
*Someone suggested lowering the engine because someone shared a video with a very similar Evinrude(?) overheat issue what was solved by lowering the engine? Lowering engine also a pain as I will have to cut the bolts, they are cheap stainless trash, tried turning one of them and tit immediately stripped, had to cut it off and replace it. Also I have no way of supporting this engine, would have to bring it somewhere with a hoist just to drop it one hole (that's all the room I have)
