BF90A prop only spins one direction when engine OFF .
CASTLE_CAPE
I just got this engine, when shut off, in neutral, spinning by hand , prop spins clockwise and makes ticking noise. Will not spin in reverse. So it only spins by hand in one directions. Is this normal? I have been getting normal and not normal for answers. I don't want to start the engine and put it in reverse of this is not normal. Thanks
Agree with NSDON.
It sounds as if the shift shaft adjustment is biased slightly too much toward a gear. But, I can't figure out in my head which way. I'm guessing forward but I'm probably wrong.
Just doing the "standard" shift shaft adjustment procedure will likely straighten things out.
