Have twin Honda BF90A from 2003, about 500 hrs. Starboard engine always had a weaker stream since purchase (Jan 2018). Now, it is "stopping". I have taken a wire and run through the exit port for the stream and sometimes it gets it flowing "somewhat". No alarms are going off.
If I use the flush port on the "port" engine the pee stream is solid, but even with using the flush port on the "starboard" side, it show little flow. I am thinking this is a blockage somewhere but reaming the line with a wire, etc... doesn't seem to help so I guess I need to pull it off.
The tube seems to wrap around the back of the engine and into some connector below the thermostat. Not sure what I should pull off to get to the connection.
Any ideas on best way to proceed?
https://www.dropbox.com/s/ksbiwnxa801szz4/UNADJUSTEDNONRAW_thumb_4a6.jpg?dl=0
