I searched this forum and did not find an exact answer for this issue. Upon launch this year my BF9.9 (approx. 2000) did not have much flow through the cooling water indicator. Upon further inspection, I notice that water was instead coming out of the idle exhaust port. I cleaned the indicator outlet with some wire and it is now coming out in a steady stream (quite forcefully at full throttle).
However, water is still spitting out of the idle exhaust port at higher RPMs. I let it idle for a long time (it did not overheat) and upon throttling up there was just a small amount of bluish smoke out the idle exhaust. However, within 15 seconds, it was again spitting some water out. I can see that at full throttle exhaust is exiting the main port underwater (bubbles shooting out of prop), so it is not (completely) plugged.
My question is: Did I break something when I briefly ran it with the indicator outlet plugged? Did water force itself around some seal and permanently damage part of the plumbing? At first I was worried about water getting into the combustion chambers, but there is no difference in engine operation. Also, after running for quite some time I immediately checked the oil and it was not milky or foamy. I find the parts diagrams do not give me enough detail to follow the exhaust/cooling water path to make an educated guess on my own.
