Hi All,
First posting - been following quite a few threads and used a lot of the info and advice to remove and clean up the carb on my Honda BF8.
Having taken it apart and cleaned it up - it seems the accelerator piston is stuck / seized.
Tried carb cleaner and penetrating fluid, but now only seem to have it stuck at the bottom of its travel instead of the top.
Any suggestions on how to free it up?
If I can't get it free, will that whole bottom carb assembly need replacing? (possibly easier just the whole carb at that point??)
Attached is a photo where I've circled the stuck part - note the photo is from before I removed the screw, and piston is now at bottom of travel. Didn't update photo as it's soaking with fluid at the moment.
Cheers
Cheers
