mickhodapp
hello folks, i am having trouble unscrewing the main nozzle on my bf8ah carb ( part#12in the boats.net diagram) to the point that the brass slot is becoming deformed & am wondering if i'm turning it the wrong way because it won't budge turning it counter clock wise.if it is not reverse threaded is it supposed to be that tight?
i have cleaned the carb real good except for the main nozzle but am not getting gas from the carb to the plugs & feel that the holes in the nozzle might be plugged. this part is obsolete so i am afraid to put any more pressure on it trying to get it out. if i ruin it then my only option would be a new carb. there is good gas in the bowl,float needle is clean & spring works & float moves up & down but i don't know if it is adjusted right. i have a shop manual with the settings but don't have a float gauge. if i take out the # 10 screw plug & shoot compressed air through it it starts up on the 2nd pull & runs fine, throttles up good & idles down fine. if i shut it off & let it sit for a couple of hours it won't start again until i take the screw plug out & do it again. any thoughts would be appreciated !
