Tom at oes
I have a 1997 BF8A. Almost every time I use it, I have to go in and clean out the thermostat and passages near it. They always clog with salt. No, it won't happen if I flush with fresh water, but it happens even during the time period when I am out for a day sail - it will be peeing fine when I leave dock, with the whole thermostat area just cleaned out, and by sunset it is clogged, partially or fully. This has happened at least twenty times and is a real pain when the wind dies...and the water flow does, too.
I've had it to the local Honda shop several times, they just shrug and tell me that "yeah, they sometimes hear of problems like this" but they don't know how to fix it. I've replaced the impeller, blew out the water tube up from the impeller, tried greasing the thermostat and passages (so the water won't condense). I've finally taken to rigging up a squeeze bottle of water to attach to the outlet hose and push fresh water through the engine backward after every time I run the stupid thing.
It started several years ago - before that it didn't happen. I don't recall any changes I made to it around the time the trouble started.
Any one have any ideas what is causing this?
