Hi, I just got this motor (8hp 4 stroke) and now it won't start and the flywheel would get stuck occasionally during the compression stage. I took of the the pull start and turn the flywheel pass the sticky point with a large screw driver. It would turn and get stuck at the next compression stage. It seems like I could turn it easily about 17 times and then it would get stuck 6 times, the pattern repeats. I took the plugs off and check to valves and their fine not sticking, cylinder walls are perfect no scrapes or carbon deposits. What could be wrong? Please help? And how to do you remove the flywheel? I took all the bolts off and it wont come off..
