Hi Folks
Got a strange one on a motor I've recently inherited...
I have come into ownership of a 2000 BF5A of the BF5AX SA 1999 model. It was originally my fathers but he has taken the big decision that he is now too old to boat by himself and will be selling his boat. The BF5A was a trolling/backup motor which has maybe seen 50 hours use since it was new in 2000. I personally collected it from the dealer in 2000 and my father is the sort who would service everything himself.
The Engine itself had been sitting on the boat in the yard for a year from 2019, but had always been run in fresh water and serviced annually by my father even if it only had a few hours use each season.
When the engine was taken off the boat it was stored on its side and apparently some of the oil did leak out.
It has been sitting upright for about a year and I've decided to start it today and this is where I have met my match...
The engine is very hard to pull start.. almost as if it has hydraulic lock.. but does pull fine after a couple of turns.. it starts well but does not run on minimum throttle. I've not seen any water coming from the head, i'm not sure if this one even has a tell tale, but water and smoke do come from the exhaust port.
I pulled the cover off today and have noticed 'something' coming from the flame catcher in front of the carb. It has the texture of thin oil oil.. but seems to be quite clean, not the color of coffee or the normal color i'd associate with water+oil mixing...
I'd been tempted to leave it into my local repair shop to get the water pump replaced but I'm wondering if this is usually something that wont make it economical to repair?
