My BF50A is 11 years old with about 500 hours on it. In June I had a totally normal outboard starting and running experience. However, 2 weeks ago in August, I could not get engine to start. Investigation revealed that intake valves were badly corroded and leaking - i.e. very poor compression, and insufficient vacuum to pump the fuel. There was a mild ring of rust at top of cylinders, above the highest ring position. Internal examination of the water galleries, intakes and exhaust showed virtually no corrosion. All gaskets, including head gasket, were in very good condition with no breaches. Generally, the engine looked in excellent shape internally and externally - except for the valves. I did discover that the 2 drain tubes to the intake air plenum were completely blocked, but it is hard to see how water could accumulate in quantity in the plenum, even with blocked drain tubes. My marine mechanic was at a loss to diagnose where the water might have come from. All water sources in his previous experience of water getting into the cylinders could be eliminated with what could be seen in this engine. My only theory left is that 11 years of damp winters with engine not run for 6 months each time has taken its toll. I will confess that I did not put a tablespoon of oil into each cylinder before storing, as recommended by Honda, because this would not have protected the valves, and I used sticky synthetic oil in the sump which I judged would protect the cylinders (which were essentially unworn, the original factory honing marks could still be seen), and any oil added through the plug holes would turn to black carbon deposited in the cylinders when the engine next run - not a good thing, as I saw it.
If anyone has ideas as to where the corroding water might have come from, I would be glad to hear.
