Hello fellow floaters! I have purchased a used 2001 BF50 Honda OB with power tilt and trim. Im finally rigging it up and am having a heck of a problem. I purchased a new remote box for it, after rigging it and hooking it up I discovered nothing works? I have power at the battery. Power at the motor where the leads connect (test light) but thats it? The pig tail is plugged in and I have no lights or alarms, power tilt/trim doesent work with key off or on? I unplugged the pigtail, just had the battery connected and the tilt trim on the side of the motor doesent work either? Fuse....maybe? Pulled the fuse located by the starter and tested it, its fine, but I put a new fuse in anyway. The positive and negative leads are on the right spot also. Is there another fuse somewhere? Since I have 0 power I assume its a fuse? We by passed the remote stuff and was able to turn the motor over by jumping the posts on the starter. I consulted honda dealers and was told to just plug in the pigtail and go. I have the correct box for the job, I researched it and spoke to two different dealers. Does anyone have ANY other ideas as to what it might be? Im all ears!
Thanks for looking!!!
JB
JB
