gazzagary46
Hi some advice please.
About a year ago I had a suspected corrosion j crack in the case. No oil leaked out and happy days after being welded. Sadly another crack has appeared on the other side. I may bite the bullet and look at purchasing a new gearbox. Reading the forums on this is seems it's linked to the threaded bearing carrier corroding and popping the case. In the uk it seems this happens a lot as there are lots of bf 50 and 40 outboards for sale minus the gearbox ! I have seen an advert for a much newer gear box for the injection 50. That has a different design bearing carrier with bolts on rather than a thread . The advert says this can be retro fitted to the carbed models like mine? It would be good to get the later design where the problem has been designed away. Are they correct it would fit the earlier engines like mine please?
Thanks Gary
Thanks Gary
