I have a 2003 BF5 I bought 8 months ago for my sailboat. The previous owner purchased it new. He says (and I do believe him) that he only ran non-oxygenated fuel in it and ran the carb out of fuel on every use. The motor ran fine for me until this past weekend. On that date, it started fine and ran as normal when I left my dock. After a day of sailing, I started the motor and found that it would only operate at wide open throttle - it then quit altogether before I made it back to my dock (but that's another story). I replaced the plug and the fuel filter and put fresh gas in the tank. It now cranks right up but still will only run at WOT.
I suspect the next step should be a thorough carb cleaning although I wonder why it would need that if the fuel has been completely run out of the carb after each use? Is a carb cleaning the right next step? If this is not the problem, what is the likely cause? Thanks for any thoughts on this.
