First, what a great forum. Thank you Marine Engine for hosting this!
New to me 1993 13' Whaler with 1994 Honda BF45A LRTA (what is the difference between BF40 and BF45??).
First short trip out last weekend, would not idle, ran good at full throttle but would only reach 4200 RPM. Carburetors need cleaning (pilot jets will be replaced), float level checked and carbs synced (with Morgan Carb Tune). I have already changed plugs (looked fine), oil, fuel filter, gear oil and impeller.
I am a bit confused about the sync process regarding blocking off the vent tubes. I have the TMO44 service manual and it does not mention blocking vent tubes and I have a piece of a newer manual that calls for blocking the SE Tubes (vents?). My carbs have a metal vent rail with the dashpot, looks like in 2004 this was changed to a different configuration (SE Tubes). Should I block off the vent tubes?
Thanks,
Matt
Thanks,
Matt
