taylormade
I've been cleaning my carbs on my 99 BF40 due to fuel overflow problems. I've basically replaced every jet and tube inside but most recently I replaced the float needles. I'm sure they're the right parts but when putting everything back together I noticed that the floats aren't level when sitting upside down. The floats lean forward at about a 30 degree angle. Is that normal or do I need to adjust them? There's not the typical screw adjustment option so I assume I'd need to bend the metal tab if I wanted to do so.
