I recently have been using and evaluating a Honda BF30D from 2010.
It was bought with 'suspected' overheating problems.
I've been out with it three times with no overheating, one with lots of WOT running. I was about to conclude that it had no issues at all, as it's also been moved down half an inch on the transom and is sucking water better than it was. It also had a wiring fault (now fixed- thanks Mike) that was causing it to run on- which I had optimisticallly told myself had been wrongly diagnosed as overheating related dieseling.
However, the fourth outing after warming up then running for about 3 minutes at WOT the overheat buzzer sounded and it shut down seconds later.
Lifting the cowl straight away, it really didn't feel particularly hot. It was comfortably touchable everywhere I could reach on the block and head. The crankshaft and flywheel had got hotter, but not too hot to touch. The flywheel bolt was totally undone... not even finger tight due perhaps to heat expansion losening it? I tightened it back up with my fingers.
I started it up again a couple of minutes later. It hardly ran, and was making a metal on metal grinding noise, but the teltale was squirting well, so I switched it off and got a tow home.
Looking at it again on shore I realised the flywheel was slipping and the whitworth key that keeps it from slipping on the crankshaft had been worn away. I guess this explains the metal on metal noise and how it hardly ran (the timing must have been more than a little out). How on earth it started is a mystery to me though! I guess the starter engaging must have been tilting the flywheel on the tapered shaft so it gripped it a bit. Temporarily I have wedged a sliver of steel plate behind the worn down whitworth key so now the engine runs- and it sounds fine albeit on the drive with muffs. Compression is good and the oil smells fine and is not emulsified.
I checked the thermostat in the kettle and it seems to be opening fine.
The waterways I can see from removing the plate behind the thermostat and the thermostat housing are very clean- no corrosion/ salt.
It squirts water at very high pressure from the teltale.
But at noticably lower pressure when I run it with the thermostat out.
I suspect an obstruction that is floating around in my waterways causing an occasional and isolated blockage. Somthing small enough to get in but too big to get out- a stray impeller vane perhaps from a previous impeller failure? I'm thinking it didn't feel hot where I put my hands but may have an isolated hotspot somewhere that I didn't find perhaps due to a single blocked gallery.
I won't have to go far to get a beat up but good runner BF25, which I could cannibalise for its powerhead then swap over the carbs, cam, CDI, but I'd like to have more of a go at fixing this one first as the fact that I've used it three times with no problems suggest that its issues may be only marginal. I could possibly just get away with running it with no thermostat, but how long would it take to die?
What's my next stage? Are there any further parts of the cooling system that can be checked without taking the powerhead off. and not requiring special Honda tools?
I know that some engines have a bit of a trap design behind a relatively easy to remove plate close to where the cooling water comes in up the pipe from the impeller, in an effort to catch some bits of impeller, salt and crud before they go too deep into the water galleries.
I'm guessing if I have to split the head and block to look in the water galleries there I won't get away with reusing the head gasket?
