fishingdad
I'm having a continual issue with water getting into my fuel line AFTER my in-line Racor.
It started about a month ago, after owning this motor for over a year with zero issues at all. I began to get the water contamination alarm after about 6 miles of travel. At first I thought I bought a bad tank of gas, but my Racor bowl was full of fuel, and no water at all. (I've replaced the Racor with a new one in case it was a faulty filter). Yet the Honda separator bowl was full of water...
Here's how my system is plumbed. My gas tank runs into a Racor filter, after the Racor it's split into two lines, one for my main Honda and one for my small kicker. My kicker runs flawlessly, and it gets the same gas. The only difference is that the fuel to the kicker is run through it's own line after the Racor, so there must be a problem with the actual fuel line (crack, hole, etc.) from the Racor to the Honda... right?
I replaced the entire line, all the way up to the Honda fuel separator itself this weekend... guess what... after about 6 miles at 3/4 throttle, boom.. the alarm started again... checked the separator, and sure enough it was full of water, and the Racor had zero water in it... WTF!?
Has anyone else had an issue like this before? Is there anywhere in the motor that water can get into the line??? This is making no sense at all!
