bf225 no power at full throttle
hitman447
Runs great up to 3/4 throttle (28 mph), at full throttle, no power. When I back off to 3/4 throttle, boat runs smooth again. Last week, top speed was 38 mph. Any ideas guys? :confused:
Simple things first. I assume no alarms are going off, since you did not mention any, and your green oil light is on while underway.
1. If you have an external fuel-water separator (which you should have), drain or replace it.
2. While underway, open your gas filler cap and see if that clears up the problem. If so, you have a clogged breather tube to your tank.
3. While underway, at the point where power is stalling out, check your pump up bulb. If flat, you have a partially clogged pick up tube in your gas tank.
4. Run a clear plastic line from your pump up bulb to your onboard fuel water separator and see if you are getting any air bubbles in it while running.
5. Drain and check both your on board fuel-water separator and low pressure fuel filter.
6. Drain your VST. On the back starboard side of your motor, you will see a plastic tube looped around a holder. Unhook it, and look down at the base where it connects. Beside the connection is a small set screw. Use a long flat blade screwdriver to open the set screw - slowly. With the end of the hose extended downward into a clear container that will hold at least a quart of liquid, start opening the set screw. Do not open too far - if it comes out, you will need to remove the lower cowling to retrieve it. Anywhere from two to three pints of gas, and maybe some water and gunk will come out of that tube. Be patient, the last stuff to come out is usually slow, but drain out as much as you can. If there is water, or any gunk, then your fuel-water separator and low pressure fuel filter have failed and need to be replaced. At that point, you should also change out the high pressure filter which sits on top of the fuel pump and is held in place with three 5 mm screws.
tRIED THE RECOMENDED FIXES ;THEN WENT INTO THE INJECTORS AND HIGH PRESSURE FUEL PUMP NOW ALL IS CLEAN now when I tried to run it for the first time the #1 coil melted ordered a new one, but i have no idea why it melted any ideas or should i just put in new coil and go from there ty
As an owner/operator of a 225, I've never seen a coil melt. They tend to be very reliable and rugged. Check your # 6 fuse - it's 15 Amp.
One of the Honda expert tech's probably need to address this issue.
I'll speculate that somehow it got cracked and water seeped in. The voltage going into the coil is insufficient to melt it, so it is likely an internal fault in the coil. Besides, if the input voltage spiked, it would have blown the 15A fuse.
