Hello,
I recently bought Proline 24 with BF225 and I am new to Honda motors.
I changed all lights near key switch to LED 12V because old light were bad and did not turn on at all. Now when I am turning switch on I have all 4 LED on for a couple seconds and then 2 (Pressure and Overheat) turn off and Battery and MIL are still on. But MIL is not so bright like I have some DTC code or during 2 seconds with key switch. I tried to test everything with service manual I found in the internet - but I don't have test harness to test ECM parameters. The light turned off completely when I took MIL wire off the 26-pin ECM connector. I tried another ECU and everything the same. Anybody knows is it ok or not?
And another problem is code 41-2. When I bought it I had codes 1 and 41-2, I changed HO2S with aftermarket, the old one was burned. The first 2 starts I had no errors. After a while I had the same codes, but only when start cold motor, when I start motor and accelerate a bit in 1-2 secs - no errors.
I changed sparks plugs, HO2S again, replace high pressure filter and o-ring (previous was leaking) and change low pressure fuel line (it leaks too). I've tried to drain VST, but screw head is rusted and stripped and I don't have idea how to remove it. Any ideas on this issue?
Thank you for your help and such a good community!
