Lucky Catch
I have a BF 225 30” lower unit that has a bad bearing. I have a spare that has about 100 hours on it. However, the spare had a 25” shaft. I would like to take the 30” shaft out of my “bad” unit and put it in my good unit that currently has a 25” shaft. I have had lower units apart to replace seals so I understand the basics. My question is…. Anything major to changing out the shaft. Is it as simple as taking the output assembly out of the case, terming the nut on the bottom of the shaft, remove the gear, pull the shaft, then put everything back together? Does anything have to be re-shimmed?
Thanks in advance for any info.
