Here is what I have done:
Drained & Cleaned VST
Replaced LP Fuel Pump - old one was a lot more difficult to push in vs the new one.
Replaced LP & HP Fuel Pump Filters and orings
Replaced Squeeze Bulb
Bypassed all external filters when I replaced the bulb and ran fuel direct from the tank through the bulb to motor.
I have fuel up to the Fuel/Water separator and can fill up the second internal filter with the pump bulb. Now here is the issue, sometimes the LP FP sucks all the gas out of the 2nd filter and the motor dies. Sometimes when I crank it up after, it wont start due to fuel starvation. Other times, I can see it dump fuel in the filter and it will run until it goes dry again. It's like there is a valve in the fuel/water separator that works at startup, but then closes after the motor runs for 10-15 min. BTW, I have dumped the Fuel/water separator many times and no water is in the bowl. I thought there is only a sensor that gets activated if water floats the bowl up, but it seems like there is a valve that is shutting off the fuel to the second filter. Also doesnt seem to be leaking air in the fuel line of oring on the fuel/water separator.
Only ideas left are problem with separator or collapsed fuel line from separator to 2nd filter. No visual issue with fuel line that I can see.
Thanks!
Byrdman
Thanks!
Byrdman
