maxthrottle
I replaced the ruined lower unit on my port 2006 BF225 last summer. Even though both engines had only 20 hours or so since the lower unit oil was changed since it was hauled out, I noticed the oil in the older starboard engine lower unit was thicker, darker and had a streak of gray paint. The oil from the new lower unit looked...brand new. I've also noticed that the engine with the new lower unit does run quieter than the original 15 year old starboard engine.
My question is this. Can cleaning and removing the ancient reside inside the lower unit gear case make a difference? Will the engine perform better or quieter? Has anyone done this successfully? If so could you recommend a procedure to flush the lower unit before refilling it with new oil?
Thanks, Bob
Thanks, Bob
