Hello All
First time poster, however, I've been reading the forum for awhile. Lot of great info on here that has helped me navigate different issues on my honda. My issue is this. I have a 2002 Honda BF225 that that I purchased used in 2007. The engine has approximately 500 hours on it and aside from this issue it runs great. When the engine is cold, ie sitting overnight or for a few days, it never starts on the first crank. It turns over and coughs a couple of times like it wants to start but doesn't. It appears to be losing it's prime as it sits for awhile. However, on the second key turn when cold it fires right up and runs great for the whole day. All day long it always starts on the first key turn. I've done the following: drained the VST, replaced the HP and LP filter with new O rings, new primer bulb, new racor on the boat, WOT 5900 rpms. No warning lights or beeps come on. Fuel and all filters are clean as a whistle. It's had all of the SB done except 56, however, the exhaust ports are higher than 6 inches from the water line. I run 89 octane non-ethanol fuel from my marina. While poking around today I noticed a dent/crack in the fuel line coming off of the fuel cutoff solenoid to the LP pump. There was no gas or leak that I could detect. I won't be able to take the lower cowling off until this weekend to check it out further. I guess my question is this, does this crack/dent appear to be enough to allow air in to the fuel line to allow the fuel system to lose prime when it sits for awhile? If this isn't the problem, I guess I'm stumped. Any thoughts or suggestions? Thanks in advance.
