Windward Pier
Greetings all. I'm the (currently frustrated) happy owner of a 2007 Everglades 211cc that came with a BF200 (approx 425 hours). I've recently had an issue come up where the boat will fall on its face after I run it at greater than +/- 4500rpm for more than a minute or two. I can easily power it up on plane then back off the throttle and run at a 4-4500 or so cruise (30mph) but a minute or so after increasing speed will feel like it ran out of gas or hit a sandbar; instinctively I always pull throttle back to idle immediately and it his not yet stalled out. Below are some details as to what I've checked so far:
- no engine codes/alarms
- runs great up until said issue
- ample fresh fuel w/ stabilizer (67 gallon tank)
- checked and replaced racor fuel/water separate - no debris or water
- replaced primer bulb
- replaced on-engine filter & checked on-engine fuel/water separator
- replaced complete VST w/ new Honda unit (seemed like most likely culprit but didn't cure issue)
- vacuum check on system from racor to VST; no leaks
- no signs or smell of fuel in bilge, etc.
- checked condition of low pressure pump diaphragm; not torn or deformed
- ran boat with filler cap off - no difference
- general service is up to date (plugs, oil change, etc.)
I still feel like I'm dealing with a fuel system problem and will try running the motor at WOT on an external tank to prove out the rest of the relatively inaccessible items (fuel pickup/screen & anti-siphon valve partially blocked) this weekend. I have not had a 2nd person available to check the primer bulb to see if its sucked flat during any of these instances.
Please feel to chime in and let me know if you think I've missed anything on the fuel delivery side and/or let me know if anything else might cause this behavior. I can't image its spark w/ the individual coils or any major mechanical problem (e.g. low compression) with how well the boat runs otherwise. Any and all help is greatly appreciated.
