SV EmeraldSea
We have a 2013 BF20 with a cooling problem. There is cooling water coming out the pee hole but as the engine warms up, gets hot, the amount of water streaming out either is the same or reduces to an near trickle. As I rev up the engine the amount of water being emitted does not increase as it did before. And then as the engine gets hotter it will sputter and stall. This happens within 10-15 mins of operation (we are in a tropical climate). Im assuming there is a temperature sensor that is commanding it to stop until its cool enough to restart. Im at a loss now as to what it is as I have done the following: replaced the impeller/housing, replaced the thermostat; replaced the pee pipe from the nipple to the shroud connector; ensured there is no debris at the base intake grills. If there is debris in the internal piping, how does one get into this to clean it out? Any tips or tricks are welcome.
Steve
Steve
