Hi I have 2 bf20's on my sailing cat, the starboard engine won't start (will manually, and runs fine)
The power trim also stopped working at the same time. the starter makes a soft clicking noise as if theres
a flat battery(batteries are fine and port motor starts and trims fine) the trim also acts like not enough power.
When motor is idling the power trim works better.
I've checked all wiring for corrosion and all seems fine,looking at the wiring diagram, could it be the power tilt relay?
thanks brett
thanks brett
