Hondaeggbeater
BAEL 1300019 2hp. Bought used and ran perfectly that year. Always ran out the carb each use. Emptied the fuel for winter. Next season only fired while pull starting. Replaced with new, the carb , coil and spark plug. Started on second pull and idle to half throttle is perfect. Half to full throttle it breaks up/looses rpms. But for seconds or a minute runs perfectly. I replaced the coil again. No change. I cleaned the carb and wired the ports out and blew it clear. New gaskets. No change. Am I looking at valve clearance problems? Weak valve spring? Head gasket is good and cylinder is not scored. Exhaust system is clear. Gas is new. Ideas?
