We have a pair of BF175's (2007 models) on a power cat. One of them has suddenly started to lose it's fuel prime when sitting idle. If you pump the primer bulb it will start and run fine. If you stop and restart again within 30 mins (maybe even longer) or so it will again start and run fine. Leave it sitting for an hour (could be a bit longer) or more and you need to pump the fuel primer bulb hard again. Primer bulb is soft when you first try to pump it after the engine has been sitting. Any thoughts?
