Hi All.
Thanks in advance for your time and advice.
I’m Running twin 2013 bf150s on an 2013 Seasport.
Last outing, while at cruising speeds (about 4200 rpm) I started getting an intermittent alarm while underway. The alarm is a loud steadily pulsing beep coming from the console where the gauges and controls are all mounted. It is not a steady tone, and all gauges read normal while happening. Not red light. No other tells on the digital readouts of the gauges. All systems normal, except the loud recurring beep.
After shutting it down, restarting the motors and getting back up to cruising speed the alarm would sound again. But There was no predictable cause or interval (like when your thermos start failing and sticking)
Sometimes i would run for half an hour before alarm. Other times just a few minutes before it started alarming. With the lack of any pattern and the lack of any other operational problems I could discern, I just finished the return to the docks and let the alarm scream. Sometimes it would stop after 15-20 beeps and start again a few minutes later. One alarm session lasted long enough I stopped counting.
Made it home just fine, pulled the boat and am preparing to start trouble shooting in the blind.
Any tips or ideas would be great.
It it helps, I bought the boat 4 yrs ago and have put about 500hrs on it since. I perform regular annual maintenance, along with some additional repair as things failed (coil pack, trim/tilt motor, impellers, etc). None of which immediately precede this latest alarm mystery so seem to be unrelated.
