Bustedknuckle
Hello,
I have an 2019 Clearwater 2508 with Twin Honda BF150s and only non Ethanol has ever touched these motors. It has been about 9 months since I have taken the boat on water. Port engine runs fine. I'm looking for help on my recent trip. My starboard motor would run up to 3500 rpms for about 5 seconds trying to plane but then lose rpms and die out. I can restart the engine again fine and runs up to 2000 rpms fine but nothing more. If I turn it off for a few mins, I can run it again over 2k to about 3500 again before it starts to die out. I have done the following services. 1. Recent Engine oil change
2. Water fuel separator was changed in the last yr,
3. Low pressure and high pressure fuel filters have been changed out. within last 9 months.
Is this a symptom of the VST not getting enough fuel supply in and starving the engine. If so, would that mean I'm looking at the low pressure pump or could the hand bulb have a restriction in it? I had to replace the Port sides hand bulb for a different issue already.
Or is this a complete different issue? Thanks in advance.
