If you are just checking timing, that will probably work.
If the chain has jumped a notch and you are actually resetting the timing...you also have to align the crankshaft timing mark. In general, the only way I know to reset the timing chain once it has jumped a notch is the remove the chaincover. As you can see there are a lot of other things that you have to take off to get to it.
If your chain has jumped timing, it is time to change the chain, the chain guides and the tensioner.
Since you are ordering the manual, there are about 6 pages on how to remove and reinstall the timing chain. It has several steps. It is not rocket science, but I know of no short cut. I have tried it and was not successful. Someone else may know of a easier way, but I do not know. if you follow the book, you can not go wrong. I have only had to do it about four times. It just takes some time, patience and the right special tools.
If you do this, you will have to remove the thermostats. As you may know, they are different temperatures, so be sure you install them into the proper locations.
Good luck!
Mike
